VU ramp-up pattern Messages in this topic - RSS
How do I setup this test case :
  • Target 500 VU
  • START with 30VU
  • After 30 min, Increase VU to 100
  • After 30 min Increase VU to 200
  • After 30 min Increase VU to 250
  • After 30 min Increase VU to 300
  • After 30 min Increase VU to 350
  • After 30 min Increase VU to 400
  • After 30 min Increase VU to 450
  • After 30 min Increase VU to 500
  • STOP
  • Is this possible?
    Currently StresStimulus supports step load pattern with constant VU increments as described here http://support.stresstimulus.com/display/doc47/Load-Pattern
    For example, you can start with 50 VUs, and then every 30 minutes ramp-up 50 more VUs. As a result, you will get:
    1. START with 50VU
    2. After 30 min, Increase VU to 100
    3. After 30 min, Increase VU to 150
    4. After 30 min Increase VU to 200
    5. After 30 min Increase VU to 250
    6. After 30 min Increase VU to 300
    7. After 30 min Increase VU to 350
    8. After 30 min Increase VU to 400
    9. After 30 min Increase VU to 450
    10. After 30 min Increase VU to 500
    11. STOP
    Would the above load pattern work for you?
