Verify Test Case Group Messages in this topic - RSS
how can I verify a test case group?
In order to verify a test case group you have to run a test with 1 VU for 1 Iteration and then query the results. Here are the steps:
  • Create a test with Steady Load and 1 VU
  • 2.Set test duration to 1 Iteration
    3.In result storage set Purge response bodies to None
    4. Run the test. If you have more than one test case group, make sure to set the mix weight 0 of all of them but the one you are trying to verify
    5. After the test is complete then click the Details button to bring up details grids. Then select VU details from the top dropdown. Right click on the first row and click Show Sessions
    6. In the Sessions grid on the left, select all sessions (Ctrl+A) > Right click > Compare w/ multiple recorded sessions. This will bring up the verify screen.
