ASP.NET Auth Cookie Doesn't Expire properly
David Posts: 7
5/28/2012
***Resolved on 5/28/12*** I typed a full bug report but your site crashed... Anyway- this cookie is cleared by ASP.NET calling Set-Cookie, setting the value to empty and expiry date to 1999. When the test runs, you can see the set-cookie expiry in fiddler, but the subsequent request from your tool re-sends the auth cookie. PS we rename our forms auth cookie to something else, but that shouldn't matter- the engine should be correctly observing the expiry of the cookie? FormsAuthentication.Signout() is the method called.
5/28/2012
Hi David,
You are correct. I see the exact issue that you've described. When StresStimulus receives a response with the cookie expiry date that is in the past, it stops to auto-correlate this cookie, instead of stopping to send it altogether . We fixed this bug and released the new build. Please install it from http://www.stresstimulus.com/default.aspx#dwnld
Let me know if it works correctly for you.
Also, as a token of our appreciation for helping to make StresStimulus better, I would like to forward you a StresStimulus Pro Unlim. VU weekly pass (this is not a trial). I will send the details in the private message.
Thanks David! -Vadim
David Posts: 7
5/28/2012
Wow- great thanks.
We are evaluating your product at the moment so the quick turnaround as well as the license really helps with this
Will let you know if it helps.
David Posts: 7
5/29/2012
Confirmed this does indeed fix the cookie problem
we are getting some other issues- will raise new forum posts.
5/29/2012
Hi David,
Thanks for confirming the fix. I will mark this issue is resolved. Will check your other posts.
Cheers, -Vadim
Emil Kuriakose Posts: 1
9/14/2013
Hi David,
Scripts recorded using Fiddler (Version 4.4.5.3) and converted to StresStimulus script and it works fine until the application/web server is restarted…After the application/web server is restarted… previously recorded StresStimulus script does not work..How to resolve that?
Thanks, Emil
9/14/2013
Hi Emil, I moved your question to a separate post and answer it here. Cheers, -Vadim
