Test output with variab. from different testcases Messages in this topic - RSS
Is it possible to extract 2 variables from 2 different test case names at same time? Dropdown allows selection of only one test case at a time.
The test output feature is described https://support.stresstimulus.com/display/doc54/Test+Output
You can select multiple extractors from multiple test cases at the same time. To add an extractor from another test case, select the test case from the drop down, select the extractor, and click the > button to add it to the output list.
