Share how you use StresStimulus.
Initial StresStimulus screencast tutorial
Max @StresStimulus Administrator Posts: 101
11/2/2010
Step 1. Recording test scenario
- Navigate through your application to capture test scenario in Fiddler.
- Click StresStimulus tab.
- Select HTTP sessions for testing.
 Step 2. Running test
- Set number of virtual users.
- Set think time - wait time before subsequent user action.
- Set number of test iterations or test execution time.
- Click Start Test. StresStimulus will playback recorded scenario under load until completion.
 Step 3. Analyzing results
- After test is complete StresStimulus displays:
- test performance measurements;
- per page performance metrics.
- Paste to Excel performance report for further analysis.
DSF Posts: 29
8/30/2021
Hi Max,
Is it possible to pull in server perfmon counters when testing this way? With the test run this way, is it possible to run then via command line like you can do with an actual StresStimulus test?
DSF.
George @StresStimulus Administrator Posts: 570
9/1/2021
You can monitor the server performance counters by using PerfMon Agent as described here. PerfMon Agent counters are also supported during command line tests.
