Extractor value does not update Messages in this topic - RSS
Balint Nagy
Balint Nagy
2/12/2014
Balint Nagy
Balint Nagy
I created a test, where the first page is a login, that returns a session id.
I created an extractor, to access that session id. I tested it, it gets the correct value.
I have parameterized subsequent pages with the extractor.
Problem is, that when I run the test, and check test results, the sessionid does not change. It seems to be stuck at a previous value (perhaps when the extractor was created?).
What shall I do to make it work?
Thanks,
2/13/2014
You can check whether your extractor worked correctly after the Verify step. After you run Verify, select the Extractor Verification tab. Check the value of your extractor and make sure it's the expected value.
If the extractor value is accurate, then check the parameters that use this extractor, if they are created correctly.
Here is the link to the parameterization guide.
Regards
