Scripting and Load testing interface
Maddy Posts: 8
2/9/2018
Scripts and Load test interface should be separate. While running the load test, all the other features/screens get locked out. I should be able to write scripts, look at script details when a test is running.
George @StresStimulus Administrator Posts: 570
2/9/2018
Thanks for sharing your thought. We will discuss your suggestion internally.
Just to give you a workaround, for now, if you have another machine, you can install StresStimulus there and use it for designing tests and scripting. From that machine, you can open script executed on the 1st machine, as the script is not locked during the test run.
