Script works and then breaks Messages in this topic - RSS
Do you have you any suggestions for test that runs with no errors some times and then with many errors, not even making it through crm login at other times?
The Verify uses the exact same parameters for the no error and many errors runs.
Do you have a load balancer in your environment? Routing to one of Web servers in the web farm may be broken.
Also, do you know if your application uses an anti-forgery token? If you're not sure, rerun autocorrelation on your script. If your anti-forgery token expired since the recording, then rebuilding autocorrelation will create a new parameter that should fix your script.
