Running multiple test cases sequentially. Messages in this topic - RSS
DSF
DSF
8/23/2021
DSF
DSF
When running a performance test I need to run a test that will execute my test cases sequentially for 5mins per test case.
Running them sequentially via a TCG works however the test runs for the test duration set at 5min and then stops.
I need the test to run the test cases for 5 mins each sequentially and then stop. Is it possible to configure the test like that and if so how? If not possible at all how would you suggest I go about in reaching that goal?
Thank you.
DSF.
On every iteration, a TC group executes each test case sequentially. You can create a Loop that will encapsulate all test case elements and will execute a given number of repeats. You will have to calculate how many repeats are necessary to execute each test case for 5 minutes. However, for your requirement, I would suggest create a separate test for each test case and execute each test for 5 minutes.
