Running correlation finder got stuck on 1 request Messages in this topic - RSS
For one of my script, the auto-correlation is stuck always at one point (Request) of the script. It doesn’t move forward even if I skip for that request.
I have not come across this issue while recording the scripts for other flows multiple times.
I am not sure what is causing this halt on auto-correlation. Can you please throw some light here?
Screenshot below:
StresStimulus autocorrelation is built on a proprietary algorithm that entails scanning your script and evaluating multiple regular expression patterns. In some rare cases (for example, when an HTTP message is bloated or has irregular content like binary), scanning a pattern for a particular request may take an abnormally long time.
When you click "Skip," StresStimulus will skip all remaining patterns for this request. However, it will still try to complete the currently running pattern.
I suggest giving it up to 5-10 minutes, if you can, for autocorrelation to complete. If it still doesn't complete, then you can exclude this session from autocorrelation altogether. Here are the steps:
  • In your case, it's session #24, which has a path /s159N-Dashboard/.
  • Go to main menu > Edit > Settings > Autocorrelation tab
  • Type /s159N-Dashboard/ into Do not create extractors from these pages textbox (see below):
  • Click OK and re-run autocorrelation or rerecord the test case.
