Home ▶ BUGS & ISSUES
Abort test with 200 users threw unhandled exception error Messages in this topic - RSS
Huong Nguyen
Huong Nguyen
5/11/2011
Huong Nguyen
Huong Nguyen
***Resolved***
The test ran for a while, it seemed to freeze. I click abort, and saw this error:
http://screencast.com/t/pECexYiC
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OverflowException: Value was either too large or too small for an Int32.
   at System.Convert.ToInt32(Double value)
   at #8G.#zE.#YP()
   at #tE.#6F.#lF(#zE )
   at #tE.#6F.#jF(Object , #uE )
   at #tE.#wE.#5E(Boolean )
   at #tE.#wE.#4E(Boolean )
   at #tE.#ZF.#EE(Object , EventArgs )
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3607 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Fiddler
    Assembly Version: 2.3.3.5
    Win32 Version: 2.3.3.5
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Fiddler.exe
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Xceed.Zip
    Assembly Version: 4.3.11069.16410
    Win32 Version: 4.3.11069.16410
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Xceed.Zip.DLL
Xceed.Compression.Formats
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Xceed.Compression.Formats.DLL
Xceed.Compression
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Xceed.Compression.DLL
Xceed.FileSystem
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Xceed.FileSystem.DLL
Be.Windows.Forms.HexBox
    Assembly Version: 2.2.0.2
    Win32 Version: 2.2.0.2
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Inspectors/Be.Windows.Forms.HexBox.dll
Samples
    Assembly Version: 2.3.0.6
    Win32 Version: 2.3.0.6
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Inspectors/Samples.dll
Standard
    Assembly Version: 2.3.3.2
    Win32 Version: 2.3.3.2
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Inspectors/Standard.dll
StresStimulus
    Assembly Version: 0.8.4146.35707
    Win32 Version: 0.8.4146.35707
    CodeBase: file:///C:/Documents%20and%20Settings/devtester/My%20Documents/Fiddler2/Scripts/StresStimulus.dll
SimpleFilter
    Assembly Version: 2.3.3.3
    Win32 Version: 2.3.3.3
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Scripts/SimpleFilter.dll
Timeline
    Assembly Version: 2.2.9.0
    Win32 Version: 2.2.9.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Fiddler2/Scripts/Timeline.dll
Microsoft.Vsa
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.Vsa/8.0.0.0__b03f5f7f11d50a3a/Microsoft.Vsa.dll
Microsoft.JScript
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll
JScript Thunk Assembly
    Assembly Version: 0.0.0.0
Accessibility
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
-v5Hm80q
System.Web
    CodeBase: file:///C:/WINDOWS/assembly/GAC_64/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
{bc68598a-b62e-4f28-8ba1-23f8811b5a09}
WSFiddlerAddinLicense
    Assembly Version: 1.0.0.0
LogicNP.CryptoLicensing
    Assembly Version: 6.0.0.0
WS.Updater
    Assembly Version: 1.0.0.16425
System.Runtime.Serialization.Formatters.Soap
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll
ZedGraph
    Assembly Version: 5.1.2.878
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_64/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thanks for reporting the exception, Huong. We will post fixed version shortly.
I am curious, when you say freeze, did you noticed whether Elapsed Time counter stopped and whether all Requests counters stopped advancing?
Huong Nguyen
Huong Nguyen
5/11/2011
Huong Nguyen
Huong Nguyen
Yes, I believe so. The Elapsed time value should not be greater than 1 hour, and I let it run for 3+. From the screenshot, the elapsed time is still at 10 minutes so I believe that counter did stop moving. I was basing the state on the progress bar more though.
Huong Nguyen
Huong Nguyen
5/16/2011
Huong Nguyen
Huong Nguyen
Installing the hotfix http://www.stresstimulus.com/forum/hot-fix-for-version-4146-142 gave the same error as here: http://www.stresstimulus.com/forum/https-interception-failure-147
The HTTPS error should be resolved by this cumulative hot fix.
Huong Nguyen
Huong Nguyen
5/17/2011
Huong Nguyen
Huong Nguyen
Confirmed for me.
Super!
