Recorder not connected to StresStimulus
Unregistered User Posts: 514
1/18/2013
When I start recording a test case, the recorder displays a message "You are not currently connected to StresStimulus".
I still can record my test case, but how to get rid of this message?
1/18/2013
This message is caused by compatibility issue with Fiddler 4, which is still marked as beta. If you will replace it with Fiddler 2, the message will disappear. Fiddler 2 has the same feature set as Fiddler 4, plus it is not in beta. Cheers, _Vadim
