Pass / Fail Configuration settings Messages in this topic - RSS
Can you please explain if there are any Pass / Fail Configuration settings that you would recommend that I turn on instead of leaving all them on Off? Currently, all of the settings are turned off so every test passes regardless of the performance. However, I do not think that this should be. I want to keep Timeouts turned, but I am wondering if there are any other settings within this menu that you would recommend that I turn to on that will be a better indicator of whether the test passed or failed?
Pass/Fail configuration options are described http://support.stresstimulus.com/display/doc52/Configuring+Test+Pass-Fail+Qualification
You will probably want to setup a transaction missed goal pass/fail criteria. However, you will first need to establish a baseline goal for your transactions as described http://support.stresstimulus.com/display/doc52/Page+Goal
