About parameterization...
Davide Restelli Posts: 4
11/19/2013
Hello
First question: using "verify" and "run parameter finding" I would have expected that StressStimulus had configured dynamically some fields such as querystring tokens or cookies. (like creating extractor - saving variables) However, in the column "replace with" I find myself with only dots, which seem to me that StressStimulus is replaying the original value of the column "recorded value". Is that correct? This means that I have to configure each parameter manually for each request?
Another question: how the auto-correlated parameters works in detail? it seems to me that it's using the default values?? coming from the server if they are not modified, and propagates the value from the previous request to the next one. Correct?
Thank you
11/19/2013
Davide,
On your first question: Parameter Finder finds possible missing extractors and parameters, but does not create them. If you wish to create all recommended parameters automatically, then after running Parameter Finder, run Auto-Configurator.
 If you want to have more control over your test settings, then instead of Auto-Configurator, use Parameter Wizard. it allows to review and create recommended pre-configured parameters one-by-one. Its not guaranteed that Parameter Finder will locate all missing parameters. Were any parameters located in your test and did you use Auto-Configurato or Parameter Wizard?
On your second question: Correct.
Copyright © 2022 Stimulus Technology
