Home ▶ BUGS & ISSUES
Pacing and Constant iteration delays do not work for me in beta v3.5 Messages in this topic - RSS
1/4/2014
I have tried ramped and steady loads, as well as timed vs. number of iterations, and iteration delays are not working: the next iteration is started immediately. I have uploaded the test case to the support repository.
1/6/2014
It doesn't seem like think time is working correctly either: I have pages that are processing in about .3 s, but most requests aren't moving from pending to received until after the think time has passed. I'm having a hard time pinning down the issue, but the behavior is drastically different from before I changed to the beta. The beta is basically unusable because none of the options for spacing out requests are working as I expect based on my past usage.
1/6/2014
Thanks for pointing out the issue with iteration delays. We just released a new beta revision with the fix.  Here are the notes.
Could not confirm the second issue. Try the new version and let me know if you are still experiencing it.
