Number of users vs number of data sets Messages in this topic - RSS
Suppose we are running for 200 users do we need to provide data set of 200 users data in stress stimulus.
Yes, it would be recommended to have at least 200 records. Otherwise, the records will be reused.
+1 link
Harish
Harish
10/17/2019
Harish
Harish
What if I want to delete the record after its use?
Harish,
If you have more records than needed for the test then you can delete the used records after the test is over.
Alternatively, you can use dataset ranges that are described here. Using this method, you can create a dataset with many records and use a new subset of records on every test run.
+1 link
