Monitoring HP-UX Messages in this topic - RSS
I want to add some HP-UX monitors to the scenario. Can you please tell me what other info is missing or how I need to add it? Please see the screenshot below.
StresStimulus can monitor servers via SNMP protocol. The documentation has a few configuration examples for different OS: one for CentOS/Red Hat http://support.stresstimulus.com/display/doc45/CentOS+RedHat+Configuration and one for Ubuntu / Debian http://support.stresstimulus.com/display/doc45/CentOS+RedHat+Configuration
Once your server is configured, you should be able to add a counter using the following information:
  • Your HP-UX host IP address or domain name without "//". Example: 10.2.2.169 or WEB_SRV5.
  • Change Community, if necessary.
  • Select a counter from the drop-down. The boxes OID and Name will be populated. If your system maintains different OIDs, then enter the correct OID and Name.
Check this page for additional information http://support.stresstimulus.com/display/doc45/Linux+UNIX+Servers+Monitoring
Try to consult your HP-UX network engineer for assistance with your server configuration, connectivity issues and performance counter information. Unfortunately we have limited capabilities to troubleshoot SNMP on our customer's’ networks.
