Missing Default Timeout setting Messages in this topic - RSS
shammann
shammann
7/10/2017
shammann
shammann
It appears from the documentation like there is supposed to be a setting for "Default Timeout (s)" configurable at the test case level. However, in the StresStimulus software I have installed, that seems not to be the case - there is a setting for "Timeout (s) at the request level, but I want to set a global default. There's a "Request Timeout" setting at the test case level, but possible values are just "Enabled" / "Disabled". How can I set the number of seconds for the default timeout in the current version of StresStimulus?
Thanks much!
The best way to set the timeout on every request is to do it inside the script editor http://support.stresstimulus.com/display/doc46/Scripting. Open the script editor and hit Ctfl+f to bring up the Find/Replace dialog. Find Session and Replace with Session Timeout=”xxx” where xxx is the timeout you want to set. Note the default timeout is 60 seconds. Click Save & Exit to save changes and close the editor.
