Migrate scripts between machines Messages in this topic - RSS
If we are planning to migrate scripts from Machine A to Machine B, what all files we need to copy and is there an option to export the Auto Correlation pattern as well?
To copy test scripts from Machine A to B, copy the configuration file (.ssconfig file) and the test sub-folder ( https://support.stresstimulus.com/display/doc53/Test+structure)
To copy the Autocorrelation patterns file from Machine A to B ( https://support.stresstimulus.com/display/doc53/Custom+Patterns):
  • On Machine A open autocorrelation templates Main Menu > Tools > Auto-Correlation…
  • In the appeared dialog Main Menu > File > Export pattern set > Export patterns to a file.
  • On Machine B open autocorrelation templates Main Menu > Tools > Auto-Correlation…
  • In the appeared dialog Main Menu > File > Import pattern set > select the file from step 2
  • 0 link
