Logout transaction metrics not displayed Messages in this topic - RSS
We have a project requirement wherein the Login and Logout transaction for a test case has to happen only once i.e. Login should happen only during the first iteration and the Logout transaction should happen only during the last iteration. Below is the settings we have chosen to achieve this.
Login transaction:
Logout transaction:
But when we run any executions with this setting, the metrics related to Logout transaction are not getting captured even after the completion of the execution. Can you please let us know if we are doing it right or is there any other way by which we can achieve this?
The reason there are no metrics for the Logout transaction is because it is not being executed.
If your test completion criteria is Run duration then “After the completion condition is reached” property must be set to Wait for iterations to complete, otherwise StresStimulus can’t determine the last iteration.
