Load testing using a predefined set of requests.
Unregistered User Posts: 514
2/3/2012
I'm looking for a way to load test our API using a predefined collection of one time use POST payloads. Is this doable from your product?
2/3/2012
You can generate post requests using a predefined set of POST payloads if you are using v 1.5 or later. To do so: 1. Store the POST payloads in a one-column csv file and import it as a dataset.
 2. Create a test case with a single POST request to the server with any payload. 3. Using parameterization editor control, replace the recorded payload with the dataset value, using “sequential” databinding method.
After that configure your load the way you need. StresStimulus will simulate a sequence of requests using each of your predefined payloads once.
