Browser and network mix Messages in this topic - RSS
I had a question about the general use of the mix weight value.  What kind of values should be in there?  Does it work like a percentage
The mix weight values are used as percentage, if the sum of all weights that you've entered totals to 100. For example, T1 with weight 20 and DSL with weight 80 mean a mix of 20% T1 and 80% DSL.
Instead of percents you also can use weights. For example, T1 with weight 1 and DS with weight 4 will give the same result.
