Load test with variable logins Messages in this topic - RSS
I would like to try a lot of accounts for login test. How could I setup variables as the body request?
If your application uses form authentication, then check the section Application Authentication on this page http://support.stresstimulus.com/display/doc46/_Authentication regarding parameterization logins.
More broadly, to import external data into the test, use the dataset variables. First, create a dataset as describe here http://support.stresstimulus.com/display/doc46/_Datasets
Then to parameterize web forms, use the parameterization grid described here http://support.stresstimulus.com/display/doc46/Parameterization+Grid
If your application uses another type of authentication, then check the section Server Authentication on this page http://support.stresstimulus.com/display/doc46/_Authentication regarding parameterization logins.
