Home ▶ BUGS & ISSUES
Load test results not getting saved due to error Messages in this topic - RSS
prashanth.bvb
prashanth.bvb
2/10/2021
prashanth.bvb
prashanth.bvb
I am running a load test execution for 13 scenario using 6 agents. The load test execution is going fine. But while saving the results, i am getting the following error. Due to this none of the results are getting saved apart from Agent details.
Below are the trace logs
01:31:27.057 - ---Begin saving results---
01:31:27.758 - Saving Summary
01:31:28.555 - Saving Sessions
01:31:32.664 - Saving Transactions
01:31:34.305 - Saving Agents
01:31:34.977 - Saving VUs
01:31:35.617 - System.Exception: Duplicate key in StresStimulus.Results.Tables.VUResultTableItem ---> System.Data.Linq.DuplicateKeyException: Cannot add an entity with a key that is already in use.
at System.Data.Linq.ChangeProcessor.TrackUntrackedObjects(MetaType type, Object item, Dictionary`2 visited)
at System.Data.Linq.ChangeProcessor.TrackUntrackedObjects()
at System.Data.Linq.ChangeProcessor.SubmitChanges(ConflictMode failureMode)
at System.Data.Linq.DataContext.SubmitChanges(ConflictMode failureMode)
at StresStimulus.Results.TestResultSaver.trySubmitChanges()
--- End of inner exception stack trace ---
01:31:36.133 - Saving Errors
01:31:36.758 - Saving Test Cases
01:31:36.961 - System.Exception: Duplicate key in StresStimulus.Results.Tables.VUResultTableItem ---> System.Data.Linq.DuplicateKeyException: Cannot add an entity with a key that is already in use.
01:31:37.039 - System.Exception: Duplicate key in StresStimulus.Results.Tables.VUResultTableItem ---> System.Data.Linq.DuplicateKeyException: Cannot add an entity with a key that is already in use.
01:31:37.039 - ---End saving results---
01:31:37.711 - System.Data.Linq.DuplicateKeyException: Cannot add an entity with a key that is already in use.
at StresStimulus.Runtime.PanelHelper.SaveGraphCurves(IGraphInfo[] graphs)
03:11:00.105 - End of test
Can you please check what version of StresStimulus you are using and are all the load agents are on the same version as the controller? If one of the agents uses an older StresStimulus version that misses a primary key field added in the newer version, it may cause a duplicate error.
Also, can you please describe the following information:
