Is it possible to postpone a load test?
Manuel Crespo Posts: 1
10/26/2012
Hello,
I would like to know if it is possible to program what time I want the load test be done. Thanks
10/26/2012
Hi Manuel, You can schedule a test using the approach described in the item 4. Command line and scheduling of this post http://www.stresstimulus.com/blog/post/v09-release-part-3-more To do so, with Fiddler closed, schedule execution of the following command line using the task scheduler:
Fiddler.exe /SS [/quiet ] <MyTest.ssconfig>
