IP Spoofing with load agents Messages in this topic - RSS
We have 3 VMs to run the test and I also installed the SS and licenses on these machines.
Now, I am trying to use multiple IPs (IP Spoofing) to make a realistic load scenario.
As I understand the network team should setup and provide the IPs which are not used .
Does it also require to set up and associate those IPs to the Load Agent or the SS controller machines by network team?
IP spoofing is fully described https://support.stresstimulus.com/display/doc54/IP+Spoofing
You are correct; the networking team must associate multiple IP addresses to each VM. Then you have to add associated IP addresses to the VM’s network cards and then add them to the list of available addresses in StresStimulus as described https://support.stresstimulus.com/display/doc54/IP+Spoofing
