how to rerecord and append existing test case Messages in this topic - RSS
Sudha chow
Sudha chow
6/17/2024
Sudha chow
Sudha chow
I get options of add to existing test case but prompts me to record from the beginning. Any help is appreciated
One way to append new recorded transactions to an existing script is as follows:
1. Record a new script in the same test (described: https://support.stresstimulus.com/display/doc59/Recording+Test+Case)
2. Clone the transactions from the new script to the existing one (either by cloning, described: https://support.stresstimulus.com/display/doc59/Clone+Objects, or by drag-and-drop, described https://support.stresstimulus.com/display/doc59/Drag+and+drop+cloning)
However, it will only work if your new recorded transaction is compatible with the existing script. Otherwise, your application will not be able to process the new script playback.
+1 link
Sudha chow
Sudha chow
6/21/2024
Sudha chow
Sudha chow
Thanks George will try that
