How To Replay Sessions Slower Messages in this topic - RSS
I record a scenario 10 minutes long. There are 10 keep-alive requests sent (one for every minute), but when I replay this test with one user, it completes much faster.
Shouldn't the replay take 10 minutes like it did when it was recorded?
While in some cases a test requires fast replay of the recorded sessions,  in your case, as you correctly noted, the sessions should be replayed exactly as they were recorded. To achieve that, the following two conditions are required:
  1. Because the  keep-alive requests are triggered by a JavaScript,  StresStimulus most likely marked them as dependent requests. You need to mark them as primary, as shown below.
  1. “Think time between pages“ should be set to Recorded, as shown below.
