How to record Mobile scenario Messages in this topic - RSS
I’m evaluating StressStimulus and deciding whether to use this tool for my load test.
I’ve tried using few mobile application, however it is not working for some of the mobile applications during recording testing case.
Do you have any guide or real case example for me to refer on how to perform load tests on mobile apps?
Recording a test case from mobile devices is described here http://support.stresstimulus.com/display/doc51/Recording+from+Mobile+Devices
You need to configure a proxy on a mobile device as described there. The device should use Wi-Fi. The Wife router and a StresStimulus machine must be on the same subnet.
Also, to record secure applications you need to enable SSL on the mobile device as described here http://support.stresstimulus.com/display/doc51/HTTPS+on+mobile+devices
If your mobile app does not support system proxy, then another option would be to use no-proxy recording http://support.stresstimulus.com/display/doc51/No-proxy+recording
