How to reach Max users with at least one complete iteration for each one? Messages in this topic - RSS
Patricia Coronel
Patricia Coronel
6/28/2011
Patricia Coronel
Patricia Coronel
I am trying to run 150 users, with the patterns:
Load pattern
Start VU: 1
Step VU increase: 1
Step Duration: 1 sec
Max VU: 150u
Test Duration:
Reaching Max Users
Warm up: 5sec
When I go to iteration details, I can see that the last 75 users, the 50% of my load, cannot complete one iteration.
How can I run a test that all the 150 users complete at least one iteration? Am I doing something wrong?
Thanks! smile
regards,
Patricia
Patricia Coronel
Patricia Coronel
6/28/2011
Patricia Coronel
Patricia Coronel
Maybe I have to use Number of Iterations and set it to 150?
Setting the number of iterations to 150 will accomplish your objective only if you use constant load pattern with all 150 VU starting at the same time.
With the step load pattern you should use “Run Duration” Test Completion criteria. First 150 sec is necessary for the last VU start its iteration. After that you need to give it a sufficient time to complete this iteration. If the anticipated iteration time with 150 concurrent VU is T on average, then set your test duration equal T +150s.
To estimate T you can either guess it or try to estimate by running first 150 VUs test with constant load pattern and the number of iterations is set to to150 (as described in the first paragraph).
