How to uninstall StresStimulus? Messages in this topic - RSS
8/23/2011
Doesn't show up in add/remove programs...fiddler doesn't seem to have an uninstall plugin option...StresStimulus doesn't have an uninstall option...and I can't see the buttons when it asks to update itself...
Since StresStimulus is an add-on and not an application, it cannot be uninstalled via control panel. To uninstall StresStimulus,  click Start button -> All Programs, find the StresStimulus group and select Uninstall StresStimulus, as shown on the image.
8/23/2011
I deleted that program group unfortunately :-p (I try to keep that programs menu uncluttered).
I can't find the uninstaller in program files.
Could you tell me how to uninstall this on the command line?
As a workaround I can suggest to reinstall StresStimulus. It will re-create the program group. Then uninstall, as described above.
Copyright © 2023 Stimulus Technology
