How to have multiple instances of StresStimulus going? Messages in this topic - RSS
Huong Nguyen
Huong Nguyen
5/10/2011
Huong Nguyen
Huong Nguyen
I have a bunch of different tests cases. Each test case is a scenario for a user role. Like 1 user is in role client, and another is in role vendor. I need to run both roles at the same time to simulate multiple type of user on the system at some point in time. How should I approach this, as it seems like StresStimulus only have 1 test run per time?
Thanks.
Hi Huong,
Mixing multiple test cases is not supported yet, but it is on development plan and will be release soon. For now I can suggest to run several test cases at the same time from different machines. While you would not be able to automatically combine graphs and reports, your server will receive adequate load, so average response time and other performance characteristics should be accurate.
Once mixing test cases is developed, I will post it here, so you will receive an auto-notification.
Huong Nguyen
Huong Nguyen
5/10/2011
Huong Nguyen
Huong Nguyen
I see, I'll look into this, thank you.
You're welcome.
Update: this feature was implemented in v2.0
