How to fix errors after creating a parameter? Messages in this topic - RSS
I recorded a scenario and it verifies without errors. However, when I create parameters using a dataset, verifies gives errors.
How can I fix it?
Often time when a parameter is created by replacing one recorded value with a data set, the same value exists in other requests and must be replaced as well. If this is not done, the script will give errors or not work as expected.
To fix this, you need to try is creating bulk parameters. To replace all instances of the recorded value with the dataset, create multiple (bulk) parameters as described http://support.stresstimulus.com/display/doc49/Creating+Multiple+Parameters+from+Editors
After that, rerun Verify to see if it helped.
