How to do trend analysis Messages in this topic - RSS
If I have multiple results then can I compare those results to do trend analysis?
You can compare multiple results side-by-side as described here http://support.stresstimulus.com/display/doc47/Comparing+Tests
Another way of creating custom reports across multiple test runs is to query SQL Server repository as described here http://support.stresstimulus.com/display/doc47/Querying+Test+Repository
Understandably, creating custom reports requires more work. Also, you would need to switch test repository to SQL Server as described in paragraph 3, 5 and 6 of this page http://support.stresstimulus.com/display/doc47/Test+Result+Storage
