HomeSUGGESTIONS & FEATURE REQUESTS
No limits in Performance counter selection Messages in this topic - RSS
Patricia Coronel
Patricia Coronel
6/14/2011
Patricia Coronel
Patricia Coronel
***Resolved in v.0.9***
Hi!
When you run a load testing,  there is a limit of 4 counters to monitor. If you want to set more than 4, you have to re run the test, but selecting other counters.
Is there any reason to limit the Perfomance counters selection when creating the load scenario?
Thanks! :-)
Regards,
Patricia
Hi Patricia,
The only reason for limiting the number of performance counters was a concern that, if too many counters are selected, it may create a performance impact on StresStimulus load testing engine. However it looks like this impact is very minor. So there is no need to keep the limit of 4.
Thanks for asking this question. We will increase the limit to 10. Would it be sufficient for your tests?
This change will be included into v0.9
Patricia Coronel
Patricia Coronel
6/14/2011
Patricia Coronel
Patricia Coronel
I think 10 is a good number, because more counters sure are going to cause a mess in the graphical data. And 10 counters all at the same time are too much too, but you know...... Maybe someone else need it.
You are doing a great job with the tool!
Regards,
Patricia
Vadim Kleyzit said:
Hi Patricia,
Thanks, Patricia.
Wanted to mention to you that v.0.9 is 95% ready, and we are testing the alpha internally.  We do not publicizing it, but if you would like to see a more feature-rich tool sooner (which I know you do Big Grin ), please feel free to download it from  http://www.stresstimulus.com/StresStimulus/StresStimulusIns...
While the release notes will be out in a few days, the most of the new features are self-explanatory with the aid of Help boxes.
Please let me know if any questions will come-up.
Vadim
Patricia Coronel
Patricia Coronel
6/14/2011
Patricia Coronel
Patricia Coronel
Vadim,
If you finally are going to implement the selection of 10 counters, don't forget to change the message in the tooltip. It continuos saying you can select until 4 counters.
Regards,
Patricia
Vadim Kleyzit said:
Thanks, Patricia.
Wanted to mention to you that v.0.9 is 95% ready, and we are testing the alpha internally.  We do not publicizing it, but if you would like to see a more feature-rich tool sooner (which I know you do Big Grin ), please feel free to download it from  http://update.stimulustechnology.com/StresStimulus/StresStimulusIns...
Vadim
Good point.! Thanks.
Patricia Coronel
Patricia Coronel
6/14/2011
Patricia Coronel
Patricia Coronel
Vadim,
Is this working in this last version? It doesn't work for me. upsetI cannot add more than 4.
Regards,
Patricia
You are right. .We did not have a chase to change 4 to 10 in the alpha yet. This will be ready in the final beta in a few days smile
-Vadim.
Patricia,
The 10 performance counters that you've suggests work in in v0.9.
Thanks,
Patricia Coronel
Patricia Coronel
6/21/2011
Patricia Coronel
Patricia Coronel
Great! :-)
Thanks a lot!
Patricia
Vadim Kleyzit said:
Patricia,
Thanks,
You are quite welcome, Patricia.
