Extractors are not visible when create a parameter Messages in this topic - RSS
We have many extractors in the extractor tree.
However, when we are trying to add a parameter in free text we can not see them when we right click on any value to replace it with a parameter.
All extractors shown on the 1st screenshot are created by StresStimulus for the purpose of autocorrelation. StresStimulus will use them to automatically create parameters.
Because the number of such extractors can be quite large, by default they are not visible in the variable picker so the user can easier see their own extractors. To unhide an autocorrelation extractor, select it and change its property Hidden from True to False.
After that, this extractor will show up in the variable picker that you can use in all parameterization controls http://support.stresstimulus.com/display/doc47/Parameterization+Controls
