Error - Within a few seconds of starting a simple load test Messages in this topic - RSS
John Banks
John Banks
9/18/2013
John Banks
John Banks
The table definition of the row size exceeds the maximum row size of 8060 bytes.
I'm getting the above in only a few moments after starting just a simple load test.
Any ideas?
9/18/2013
Can you please provide the following information:
  1. Did you change the default storage from Embedded SQL CE to SQL server? If so the what version of SQL server do you use?
  2. Please paste the screenshot of the error or the entire message text.
John Banks
John Banks
9/18/2013
John Banks
John Banks
I never made any configuration changes from the embedded CE edition.  I do have a SQL 2012 instance available, but this is the defaults.
9/18/2013
Thanks. How many VUs do you emulate from this machine? Also, what SS version do you use?
John Banks
John Banks
9/18/2013
John Banks
John Banks
Only making it to 17 users -- 3.0
Test Summary
Test Case Summary
File Name: FullTransaction.ssconfig (Wednesday, September 18, 2013 4:16:10 PM)
Primary Pages: 35
URLs : 283
Test Parameters
Test Case Mix: zzzzzz (0); Browse_Scenario (100); Login_Navigate (0)
Load pattern: Step load
Start with: 2 user(s)
Increase by: 5 user(s)
Every: 15 second(s)
Maximum: 100 user(s)
Browser Type: Chrome
Network Type: LAN
Complete after: 02:00:05
After that: Wait for the responses
Warm-up time: 5 seconds
Test Run Information
Date: Sep-18 2013
Start Time: 16:16:27.98
End Time: 16:17:23.09
Warm-up (s): 5
Aggregate Session time (s): 523.125
Test run duration (s): 55.10
Overall Result
Status: Aborted
Max User Load: 17
Total bytes sent: 1,757,792
Total bytes received: 17,630,735
Bytes sent/sec: 31,899.24
Bytes received/sec: 319,950.854
9/19/2013
Here is what you can try:
  1. In the Result Storage node set the "Purge response bodies" to All.
  2. Or, switch to SQL server as Data Storage.
9/20/2013
John,
We just released a new 3.0 build that addressed the issue with the error message you described.
If the above choices weren't sufficient you can download the new version here.
http://www.stresstimulus.com/default.aspx#dwnld
