Dynatrace settings quetion Messages in this topic - RSS
I ran a load test with Dynatrace integration turned to Yes.. But apparently we don't see these http-headers variables
PC - A Page or transaction name
* ID - A session number in the test case
* NA - The path and query of the request
* AN - An Agent name
* SN - A test case name
* TE - A test name
* VU - A virtual user number
* SI - "StresStimulus", the issuer of the request
To enable Dynatrace integration in Advanced Options set the Enable dynatrace integration to Yes.
Once you do that, StresStimulus should add an HTTP request header called “x-dynaTrace” which has all the dynatrace information
To see this header, run Verify and double click on any green check mark. You will see a compare view of recorded and replayed requests. The dynatrace header should be on the right.
