Documentation for load injectors Messages in this topic - RSS
I am in the process of setting up my load injectors. Could you please provide me with some documentation or link that I can follow or refer to.
I believe I need to install the stress stimulus on those boxes and do I need to do any other configuration?
Here are the steps to add an on-premise load agent (or load injector):
  • Install the StresStimulus Load Testing Tool on the Load Agent computer. The same installation steps as you did for installing on the controller computer.
  • Open StresStimulus on the Load Agent computer.
  • In the main menu go to Edit > Agent Options and enable Agent Mode as described http://support.stresstimulus.com/display/doc53/Configuring+Agent
  • To attach the Load Agent to a test controller computer follow the steps described http://support.stresstimulus.com/display/doc52/Attaching+Agents+to+Controlle
  • You can also use cloud load agents using AWS (http://support.stresstimulus.com/display/doc53/Creating+AWS+EC2+agents) or Azure (http://support.stresstimulus.com/display/doc53/Auto-Provisioning+Microsoft+Azure+Cloud+Agents)
    Before running a test, you need to allocate VUs between load agents, as described here http://support.stresstimulus.com/display/doc53/Multi+test+case+VU+distribution
