Do we need a license on load agent? Messages in this topic - RSS
We have successfully configured StressStimulus tool on one of our remote server machine but we want to use another machine as a Load Agent machine to run the load tests in distributed mode. Do we need to activate the license on the Load Agent machine?
You do not need to activate the license on the Load Agent machine. Here are the steps to add load agent:
  • Install StresStimulus Load Testing Tool on the Load Agent computer. The same installation steps as you did for installing on the controller computer.
  • Open StresStimulus on the Load Agent computer.
  • In the main menu go to Edit > Agent Options and enable Agent Mode as described http://support.stresstimulus.com/display/doc52/Configuring+Agent
  • To attach the Load Agent to a test controller computer follow the steps described http://support.stresstimulus.com/display/doc52/Attaching+Agents+to+Controller
  • 0 link
