Distribute load across multiple machines Messages in this topic - RSS
Do you have any documentation on how to distribute a load test across multiple StresStimulus installations?
Distributed testing is described here http://support.stresstimulus.com/display/doc48/Distributed+Testing
It includes the following steps:
1. Install the same StresStimulus software on a controller machine and all agent machines
2. On agent-machines switch to the agent mode http://support.stresstimulus.com/display/doc48/Configuring+Agent
3. Attach agents to the controller http://support.stresstimulus.com/display/doc48/Attaching+Agents+to+Controller
4. Specify how to distribute the load http://support.stresstimulus.com/display/doc48/Configuring+Load+Distribution
5. Run the test
