Datasource usages during and after warmup Messages in this topic - RSS
6/17/2013
I am using the parameterization to load a unique set of requests for each iteration (e.g. iteration 1 run loads requests for page 1, iteration 2 loads requests for page 2, etc). Are the set of parameters used during the warmup re-used after warmup? That is, if the warmup runs 5 iterations, going through parameters 1-5, does the actual test start on parameter #6 or parameter #1? From some experimentation, it appears to be starting on #6, but I wanted to confirm.
6/18/2013
You are correct.
