Search/Replace for Parametrization
Ricky Glaze Posts: 3
2/20/2012
***This feature is completed in the final v1.5 release*** Hey Vadim, I thought about a feature that would be of great help to me. I am using parametrization heavily. This means that I am hand editing a lot of requests to parametrize them. It would be very nice to have a search/replace feature for requests that supported wildcards and regular expressions. That way I could do something like: Replace All "id=*" with "id={{id}}" Thanks, Ricky
2/20/2012
Hi Ricky,
Great feature request! We already drew the line with adding new features to 1.5 due to its close release date, but I will make sure to include your request in the next version.
2/29/2012
Update:this feature was included in the final v1.5 release (early than expected). Here's how the regular expressions and wildcards support works when using find/replace functionality in the Parameterization Editor : The Parameterization Editor will automatically appear when you select any requests (i.e. POST or GET), except those that are formatted as name/value pairs. The Parameterization Editor is used to configure parameterization in AJAX / XML / free format requests that are frequently used in RIA (such as Silverlight), Web services, mobile and AJAX applications.
Simply click Find and Replace on the toolbar. Then use a regular expression or a wildcard to Find and the Parameterization control to Replace.
![](http://www.stresstimulus.com/forum/images/n/099B3B610655B34DA116E3FBCE18DF4D.png) This enhancement simplifies configuration of requests with many complex parameterization rules.
Thanks again for your great suggestion, Ricky!
Cheers, Vadim
