Collating transactions with same name Messages in this topic - RSS
Can we collate transactions (in different scripts) that have the same name together. We need to achieve this is the StresStimulus transactions report.
Transactions from different test cases are not related, even if they have the same name. Therefore, collating them into a single report cannot be automated.
However, you can try consolidating then through the following manual process:
For each Transaction Result Tab, navigate to VU Activity View and export the Activity diagram data to a .csv file s described http://support.stresstimulus.com/display/doc52/VU-Activity+View.
The exported data will include the transaction time for each VU and each iteration.
Then open/add the resulting .csv files to a single Excel file and aggregate them any way you wish. For example, you can calculate the average or median response time.
