Authentication Credentials for Many Test Cases Messages in this topic - RSS
Hello Team,
In my load test scenario I have multiple test cases and each of them will use different authentication credentials.
I have noticed that there is no individual authentication tab under Build Test Case for individual scripts. Instead all the test cases are using same authentication details which fails my scripts. Please suggest me alternative method or from where I can provide individual authentication to individual test cases from load test scenario.
In order to specify credentials per test case, you need to specify a User Group for each credential.
Check the User Groups checkbox above the authentication grid to show the User Group column. Then for each credential row, specify a user group you wish to add it to.
Then in the Managing Test Cases node, select each test case and assign a group that will contain the credentials you want to apply to it.
