perfmon counters from remote machine
Unregistered User Posts: 514
3/6/2012
I have noticed that , in the tool I’m not able to select the remote machine to add the perfmon counters of the web server machine. Is there any setting?
3/6/2012
If you do not see the remote machine in the computed drop-down, enter its name or IP address without two back-slashes as shown on the screenshot below.
To troubleshoot whether the name or IP address of the network computer is correct, launch Perfmon on the test machine and add performance counters from that network computer.
After that use the same connection information in StresStimulus.
