401 warning while recording script Messages in this topic - RSS
I have recorded a script(HTTPS) using fiddler integrated stress stimulus tool. This scripts requires NTLM authentication hence provided the credentials (domain, username, password)in authentication tab.
While replaying the script its throwing 401 warning
Check to make sure you provided the proper credentials. Also, often the domain field should be left blank in the authentication tab.
The no-proxy recording is an incorrect option for your situation. It is only necessary when proxy recording is not possible, but in your case, you were able to record a test script.
