Transaction significant slower than manual
Sune Posts: 1
3/8/2022
Hi
I am completely new to StresStimulus and am not very technical. I am currently using StresStimulus to run stress tests on a work project. When running the tests I can see that a transaction takes about 15 sec. That same transaction takes about 2-3 sec when I click around in the web application manually.
How can this be? Is there a setting I need to configure in order to get more accurate results?
Thanks in advance
George @StresStimulus Administrator Posts: 556
3/9/2022
StresStimulus response time measurement is accurate. However, when comparing it with your observation, make sure you compare “apples to apples.” Your test configuration must be adequate to your requirements. I suggest starting troubleshooting by comparing the StresStimulus waterfall graph and Google chrome waterfall graph to see where the discrepancy is.
