StresStimulus v49 gives an error for NOUI command
abhishek Posts: 4
3/22/2018
Hello,
I have installed StresStimulus version 49 on a remote machine. I have run the below command from command line:
C:\LoadTestExecutables\StresStimulus> StresStimulus.Application.EXE /noui C:/LoadTestExecutables/StresStimulus/Configs/SOAPI_NL_LoadTest.ssconfig /report C:/LoadTestExecutables/StresStimulus/Results
Command line throws below errors:
C:\LoadTestExecutables\StresStimulus> Unhandled Exception: System.NullReferenceException: Object reference not set to an instance of an object. at Fiddler.WinINETConnectoids..ctor(ProxyEndPoint endpoint) at Fiddler.ProxyServer.SetupUpstreamProxy() at StresStimulus.Runtime.Test.CreateNew(TestModel model, Boolean isDebug, Dictionary`2 hosts, List`1 changeScheme) at StresStimulus.Runtime.ConsoleRunner.CreateTest(TestModel model) at StresStimulus.Runtime.ConsoleRunner.RunTest(String[] args) at StresStimulus.App.Program.Main()
Could someone please suggest what is going wrong in here.
George @StresStimulus Administrator Posts: 555
3/22/2018
Abhishek,
Thank you for reporting the exception.The stack trace shows that there is an issue with the upstream proxy. In some network environments running tests through a corporate upstream proxy may require manual configuration http://support.stresstimulus.com/display/doc49/Upstream+Proxy+Settings
I suggest to run this test in the interactive mode to get the proxy configuration resolve first, and the interactive mode gives more user-friendly diagnostic.
After that, you can run the test it in the batch mode.
abhishek Posts: 4
3/26/2018
It's not working with the given solution. Getting the same error.
3/26/2018
We had a glitch in v 4.9 beta that was fixed in v4.9.6655. What version do you use? Install the latest 4.9 and try again.
Also, /noui flag requires a non-expired activation key.
