Run and Monitor Test disable
Unregistered User Posts: 509
4/12/2023
I am trying to access StresStimulus from local machine and unable to Perform “Verify-Auto Config” and “Run and monitor Test”. Please find attach screenshot for same. Please help me to enable, so I can use StresStimulus from my local machine.
George @StresStimulus Administrator Posts: 556
4/12/2023
According to your screenshot, it looks like you don’t have a test open. To perform “Verify-Auto Config” and “Run and monitor Test” you need to open a test. To open a test, in the main menu > File > Open Test > select a test to open. Alternatively, you may record a new test and run it as described https://support.stresstimulus.com/display/doc57/Recording+Test+Case
